roof rail weatherstrip
Old Oct 26, 2009 | 07:09 PM
vescotech's Avatar
vescotech
Default roof rail weatherstrip
I'm trying to install roof rail weatherstrip on my 66 but have ran into a snag. The weatherstrip is a Scott Drake piece (that may be the problem) and I don't have the original to compare it to. The roof rail channel has a notch in the front inside corner about an inch long. The weatherstrip has a inch piece on the end that appears to go in the notch however if you install it that way the metal mounting tab on the weatherstrip is about 3/4 of an inch away from the mounting hole. Has anyone else ran into this? Can any one post a pic of the front of their mounted weatherstrip? Thanks
Old Oct 27, 2009 | 05:39 PM
vescotech's Avatar
vescotech
No weatherstrip gurus out there?
Old Oct 27, 2009 | 06:16 PM
photocliff's Avatar
photocliff
I think there is a 3M calk type product that is smoothed into the roof rail channel
Old Oct 27, 2009 | 10:36 PM
MetalEd's Avatar
MetalEd
That is the drip rail seam sealer, I think he is talking about the rubber strip above the windows, below the drip rail.
The only thing I can think is to call the people who supplied it and see if there is a different one for your specific car. If not, then return it and order from a different company that will know exactly what you need.
foxtrot
Sep 29, 2015 06:32 AM
Sep 17, 2015 07:57 PM
2k232
Sep 16, 2015 10:28 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
zanemoseley
Sep 6, 2015 12:58 PM
