200ci starter questions
Old Nov 9, 2009 | 07:49 PM
67mustangreg's Avatar
67mustangreg
Default 200ci starter questions
When I get back home tonight I'm gonna start calling around for quotes. Any brand that's good or bad? can I get original style ford for about the same price? how to I take my old one out and install the new one. whats the insulator wire going from it to the firewall?
thanks in advance
Old Nov 9, 2009 | 08:13 PM
1slow67's Avatar
1slow67
ROTM Moderator
Should only be 2 bolts to undo to take it off. 1 on the bottom and 1 on top near the block, a wire on one of the bolts, and then the wire on the side of the starter. To put on the new one just put the wire on the bolt and tighten it back down and then just reconnect the one of the side.
I know you probably know this already, but make sure to undo one of the cables on the battery before you start.
Old Nov 9, 2009 | 09:34 PM
67mustangreg
I heard it's an easy take-off/reaasembly. thanks
also, my battery is out of my car totally so it shouldn't matter right now
Old Nov 9, 2009 | 09:36 PM
1slow67's Avatar
1slow67
ROTM Moderator
I've taken it off about 2 times now. Once for clutch and once for T5 swap.
Old Nov 10, 2009 | 01:49 AM
67mustangreg
Okay, so i got both the bolts off on the passenger side. The one od the drivers side circled in green, I cannot get off. Not sure if it's a clearance issure or a tightness issue.
Old Nov 10, 2009 | 03:28 AM
67mustangreg
the issue is clearance to turn the socket between the headers and the starter itself. anybody???
Old Nov 10, 2009 | 06:43 AM
1slow67's Avatar
1slow67
ROTM Moderator
I had to use a wrench for that one.
Old Nov 10, 2009 | 10:09 AM
JoelEsler's Avatar
JoelEsler
If you have a stock header, it's dead easy. If you have an aftermarket header, You might have to take it off first.
Old Nov 10, 2009 | 03:36 PM
67mustangreg
sitting in class this morning, it hit me. a wrench. I think you're right. Lemme go check.
Old Nov 10, 2009 | 03:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
get a really long extension thats longer than the starter and then use a ratchet to break it loose
