If I replace my headlight harness
Old Nov 14, 2009 | 02:04 PM
nba1341's Avatar
nba1341
Default If I replace my headlight harness
Will I still need to add a relay to fix flickering lights?
Old Nov 14, 2009 | 02:12 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Are you sure the flickering lights aren't because of the old harness shorting out or having a bad contact some where causing them to flicker?
I would assume a new harness would fix this.
Lynn
Old Nov 14, 2009 | 05:02 PM
tx65coupe's Avatar
tx65coupe
Its hard to say with out knowing more about your issue. When do the lights flicker and is it all of them or just the headlights?
Old Nov 15, 2009 | 01:14 PM
nba1341's Avatar
nba1341
they usuallyy only flicker on the freeway because its constantly bumpy. none of my other lights flicker.
Old Nov 15, 2009 | 01:24 PM
LynnBob Mustang
Sounds like you got a short or a loose connector some place. A new head light harness "should' fix it. Unless you want to take the other apart and look for the problem.
Lynn
Old Nov 15, 2009 | 05:28 PM
Art Brock's Avatar
Art Brock
My headlights were flickering & it was the headlight switch.
Maybe turn your lights on & shake the **** & reach under the dash & shake the actual switch & see if they flicker.
I'd also make sure the fuse is making good contact in the fuse block. I had that problem on my cig lighter, it would come & go. Bent the brass pieces that actually hold the fuse to make it tighter & problem went away.
Old Nov 15, 2009 | 07:38 PM
tx65coupe's Avatar
tx65coupe
If thats the case then it is either bad wiring, bad switch, or just a bad connection. Actually, It could just be one headlight doing it. If thats the case it could just be a bad bulb.
Old Nov 15, 2009 | 10:18 PM
nba1341's Avatar
nba1341
well the headlights constantly fluctuate in brightness when just idling they flicker on the freeway
maybe ill try that headlight switch idea first
Old Nov 15, 2009 | 11:39 PM
hiboostwoody's Avatar
hiboostwoody
Sounds like you either have a bad headlight ground connection or a bad switch. You might want to check the wiring going to the dimmer switch. I have seen it where the insulation would rub through and the wires would short out on the floor board.
Old Nov 15, 2009 | 11:41 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
what kind of voltage regulator do you have old style or new solid state?? if its the old style upgrade that....
