Will these subframes work?
Old Nov 14, 2009 | 02:55 PM
bookzguy's Avatar
bookzguy
Default Will these subframes work?
Will these subframe connectors fit on a 66 mustang coupe?
Old Nov 14, 2009 | 04:10 PM
tx65coupe's Avatar
tx65coupe
That should be fine.
I have what looks to be the same thing on mine. I have this.
http://www.cjponyparts.com/product.asp?pn=SFC1
After you install them have a muffler shop weld them for strength. I had both sides of the front welded but not the bottom so water could drain out. In the rear I had the main bracket and the tab welded. That bolt hole in the tab does not serve much purpose since there is no way to put a nut on the bolt.
Old Nov 14, 2009 | 06:21 PM
Cruzzar's Avatar
Cruzzar
They don't look to have the right shape. Shouldn't they have a slight dip, from front to back to follow the bottom of the car and shouldn't they offset from where they attach to the front subframe and to where they attach to the rear subframe. I have a '70 but I think the '66 has a similiar floor pan. Are they being presented as fitting a Mustang? They could be modified to fit your '66.
Old Nov 14, 2009 | 07:32 PM
LynnBob Mustang's Avatar
LynnBob Mustang
They look exactly like the CJ Pony ones as posted above.
Lynn
Old Nov 15, 2009 | 07:45 AM
JDraper's Avatar
JDraper
The ones in our '66 are straight with no dip and no offset. Those should, or be easily modified to fit if they're not exactly correct.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
FivePointToTheOh
Oct 2, 2015 04:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
