Headliner Sound Deadener
Ive seen some posts about the hundreds of sound deadening options...
And I'm tackling the headliner this weekend..
Does any1 recommend the best deadener for the headliner? The kit I bought came with some cheap stuff but I'm trying to do this right and tackle 1 section of the car at a time with the most efficient but best stuff.
Thanks in advance for any advice!
I did two layers of eDead sound deadener on mine, then put some "bedding" I got from a crafts store up there with spray glue to make sure the headliner fit properly and had some padding behind it. Worked great
Product by Second Skin called Damplifier Pro. Its just as good as Dynamat, if not better, and costs less. It sticks much better than any other product out there which is extremely important when doing the roof.
I think I used 8 sheets for a single layer on the roof of our 67 last spring. There is no roof vibration in our car now. Give the roof a good thump with your hand and its a solid thud.
Same stuff that is sold under dozens of names on Ebay, just a heck of a lot cheaper. Stops exterior condensation on the vehicle!
Don't know how well it would work acoustically, but should really help with temps in the summer/deserts or even cold snows. Anyone seen it or tried it? Any down side to it?
I used Damplifier and it worked great. Drop a couple of sheets into the door panels also and you will pretty much kill all the road noise in the car. and if you have any left over put it into the sail panels of the car. Between the trunk quarter and the roof It will work wonders.
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
