Carburetor problem?...
Old Dec 31, 2009 | 07:51 AM
hotrod351's Avatar
hotrod351
something else you can try is, while idling, pop the spark plug wires of, at the cap, first loosen them, and when you pull the one that doesnt make a difference then you at least konw ehich cylinder is giving you the problem, plug, wire, valve, or what ever. thats how i found a miss in mine, turned out to be a valve in my case.
Old Jan 2, 2010 | 04:16 PM
KBunny's Avatar
KBunny
I finally figured it out, there were two vacuum leaks. One vacuum leak, which I have taken care of, was a bad gasket between the carb and intake. The other vacuum leak, which I have not taken care of, is at the point that the shaft for the secondaries protrude from the passenger side of the carb. The car runs much better without any hesitation however the vacuum leak on the secondaries is noticeable at idle.
The prequel to the question is, I have rebuilt the stock 2 barrel carb on these mustangs before and that wasn't terribly difficult. I have done some basic work (jets and rods) on this carb (edelbrock 600cfm).
The question is, how do I fix this problem? is there an o-ring that I can just buy and replace or is there more to it? Thanks for your help so far.
Old Jan 2, 2010 | 10:33 PM
109jb's Avatar
109jb
A leak at the throttle shaft usually requires drilling out the bore that the shaft runs through and installing a bushing to restore the proper fit for the throttle shaft. It may also require a new throttle shaft, but usually a bushing will take care of it.
Old Jan 2, 2010 | 11:02 PM
KBunny's Avatar
KBunny
Well that sucks (both literally and figuratively) I guess I will have to live with it for the time being then. Thanks for all of the help guys.
Old Jan 2, 2010 | 11:22 PM
67mustang302's Avatar
67mustang302
I wouldn't run with a vacuum leak, you can burn an engine down really quickly that way. And yeah, it'll require a more than standard rebuild to replace the bushing/shaft.
Just buy a Quick Fuel and be happy
Old Jan 2, 2010 | 11:55 PM
KBunny's Avatar
KBunny
Well if thats the case then where can I get these parts needed to do the repair?
Old Jan 3, 2010 | 12:05 AM
67mustang302
Contact Edelbrock, they should have the repair parts for it.
Old Jan 3, 2010 | 04:50 AM
Adrenolin's Avatar
Adrenolin
Just as a note regarding the Edelbrock carb and fuel pressure since it was mentioned above. They really don't like more than 6psi and a number of issues can arise even at 6 to 7psi. I wound up installing THIS 4.5 - 9psi fuel pressure regulator and run at about 4.5psi.
I'm also running an electric Mallory fuel pump rated at 7psi however I've talked to a number of guys with the Edelbrock carbs who found 4.5 to 5psi helped.
Sep 17, 2015 07:57 PM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
Sep 2, 2015 08:40 PM
