Coil Spring Installation Help!
Old Dec 25, 2009 | 02:31 PM
pimp2303's Avatar
pimp2303
Default Coil Spring Installation Help!
I am installing my front Coil Springs on my new upper control arm and spring seat and bushing. how should the spring sit on the seat. There have this little peice on the seat that sticks out a little, is that where teh end of the spring go. or that little peice doesnt matter, long as it sits in the spring seat correctly.
A picture of someone springs would help greatly. thanks
Old Dec 25, 2009 | 02:36 PM
65Coupester's Avatar
65Coupester
The tab goes to the inside, away from you, and the end of the spring goes to the tab.
Old Dec 25, 2009 | 05:15 PM
Jonk67's Avatar
Jonk67
You've got it right, the spring end that sticks out butts up against that tab on the spring perch and the tab should be towards the inner shock tower as stated by 65coupester. The flat smooth side of the shock sits in the upper shock tower mount.
Jon
Old Dec 25, 2009 | 06:16 PM
4reboy's Avatar
4reboy
The tab can only be toward the inner shock tower on one of the sides, the other side it will be toward the front of the car
The tab should on the rear of the upper control arm regardless but on one side it will be towards the firewall and the other it will be towards the bumper, provided the perches are the same. That should make more sense.
I believe this is correct information, that's how it is on my car with brand new perches and control arms and everything else.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
