does the proportioning valve go?
Old Jan 1, 2010 | 05:32 PM
MonsterBilly's Avatar
MonsterBilly
Default does the proportioning valve go?
On the front or the back brakes?
Old Jan 1, 2010 | 05:43 PM
groho's Avatar
groho
it adjusts the amount of rear brake
Adrenolin's Avatar
Adrenolin
The PV is used to adjust the rear brake pressure. You'll want to balance the pressure to keep the rear from locking up under hard braking.
Old Jan 2, 2010 | 04:05 AM
kalli's Avatar
kalli
you have only only one line going to the back. if you have a single master it won't have a dedicated outlet to the back, it's coming from the distribution block. if that's the case mount behind the distribution block. otherwise into the single line coming from master to rear.
most prop valves allow pressure when you tighten the ****, which is quite the other way round people would think. just in case you don't have markings on the dial and it confuses you ...
kalli
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
8lug
Sep 21, 2015 01:33 PM
TfcCDR
Sep 14, 2015 12:08 PM
