transmittion problems
Old Jan 5, 2010 | 03:26 PM
matt.stoffel's Avatar
matt.stoffel
Unhappy transmittion problems
well i bought my car about 3 months ago. and about 4 days after i got it it stopped going into reverse. then after not long it stopped shifting out of first.
its a c4 on a 65'
Old Jan 5, 2010 | 04:02 PM
TexasAxMan's Avatar
TexasAxMan
Does the lever move into reverse, but the trans doesn't shift to reverse?
Could be linkage, in which case I'd rebuild the shifter and make sure you adjust it properly. Could also be the vacuum modulator, or simply the vacuum line that goes between the tranny and engine.
It's free to check the vacuum lines, so start there. Unless someone has recently rebuilt the shifter it probably needs it, that's pretty cheap too. Also, I'd change the fluid and filter in the transmission.
Hope this helps.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
