Which valve covers will fit my engine?
Old Jan 5, 2010 | 05:15 PM
sentipede's Avatar
sentipede
Default Which valve covers will fit my engine?
Hello,
I have a 5.0L 302 from a 92 fox body in my 67 and was looking to replace the Ford Racing valve covers with something different. I was wondering if the following valve covers would work with my engine.
Scott Drake Enterprises
Will year any 302 covers work? How about 351 covers?
Thanks in advance!
Old Jan 5, 2010 | 07:35 PM
tcrote5516's Avatar
tcrote5516
Yea, any year 289/302/351w covers will work.
Old Jan 5, 2010 | 08:23 PM
sentipede's Avatar
sentipede
I had another stupid question, but these valve covers each have a hole for a breather cap on both sides. My current valve covers only have a breather cap on the drivers side.
Is this ok?
Old Jan 6, 2010 | 12:46 AM
tx65coupe's Avatar
tx65coupe
Yes its fine. The other hole is for PCV valve.
Old Jan 6, 2010 | 03:56 AM
67mustang302's Avatar
67mustang302
Get something that's cast aluminum, and run the Fel Pro 1 piece rubber/steel core valve cover gasket. That way you won't get valve cover leaks.
Old Jan 6, 2010 | 07:44 AM
sentipede's Avatar
sentipede
Which ones you are referring to?
I think these are them:
http://www.summitracing.com/parts/FEL-VS13264T/
These also came up in the search:
http://www.summitracing.com/parts/FPP-1684/
http://www.summitracing.com/parts/FPP-1636/
Old Jan 6, 2010 | 10:16 AM
kalli's Avatar
kalli
I guess that's the ones he's referring to:
Old Jan 6, 2010 | 03:31 PM
67mustang302
Yup, them's the ones. But you need a good cast aluminum valve cover so there's enough rigidity in the sealing lip. Valve cover leaks are caused by crappy gaskets and crappy covers, both of which need to be fixed.
http://www.summitracing.com/parts/FMS-M-6582-L302/
I'm running those covers with the Fel Pro listed above. 0 issues with leaks, but the covers are tall(to clear any valve train you desire).
Old Jan 6, 2010 | 08:04 PM
nba1341's Avatar
nba1341
sell me those old valve covers if you get rid of them
Old Jan 6, 2010 | 10:32 PM
sentipede's Avatar
sentipede
What if I went with the Cast Aluminum 'Shelby' valve covers and a pair of spacer with 4 gaskets to achieve clearance? Would I be asking for trouble?
Valve Covers
Spacers
