Car Jack ratings?
Old Jan 11, 2010 | 08:02 PM
nba1341's Avatar
nba1341
Default Car Jack ratings?
Hello I have a car jack rated at 3000lbs. Is this good to use on my car and other? I'm not sure if the rating of the jack is suppose to be more than the weight of the car itself or not since you are only supporting one side of the car and only for a limited amount of time till jack stands are under it.
P.S. my fail at posting in the wrong section. Seriously lol I am sorry
Old Jan 12, 2010 | 06:25 AM
tx65coupe's Avatar
tx65coupe
You should be fine with that jack. Just curious, do you have a link to show what jack it is?
Old Jan 12, 2010 | 09:38 AM
oldrock's Avatar
oldrock
3000 should be more than enough since it is really only holidng half of the front or back of the car. Mine are rated at 4000 pounds but that is because I like the jacks with the wider bases not because of the extra weight rating. Probably the most important thing about jacks is making sure they are on a good solid lifting point under the car.
Old Jan 13, 2010 | 04:43 AM
tx65coupe's Avatar
tx65coupe
Agreed. Always double check that you have it placed at a good lifting point.
Old Jan 13, 2010 | 12:17 PM
jcthorne's Avatar
jcthorne
Hydraulic jacks have an internal pressure relief to prevent you from lifting more than the rating of the jack. Most of them will not quite lift the published rating. The higher rated jacks are usually more stable, but you still need jackstands.
Old Jan 13, 2010 | 10:13 PM
tx65coupe's Avatar
tx65coupe
Also you are better off with these type of jack stands.
http://ecx.images-amazon.com/images/I/416OfrmMWWL.jpg
These are not as safe.
http://www.danoland.com/nsxgarage/tools/jackstand.jpg
Diode Dynamics
28
May 26, 2022 12:02 PM
2003 4.75l
14
Aug 29, 2015 02:58 AM
2003 4.75l
Aug 18, 2015 10:35 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
