disc brakes for 9"
Old Jan 20, 2010 | 01:02 PM
suicide67's Avatar
suicide67
ok How do I tell what bearing size I have?
Old Jan 20, 2010 | 04:13 PM
67mustang302's Avatar
67mustang302
Look at the bearing retainer plate that bolts the axle in. I know on Wilwood's site they have a picture selector for kits that show what each bearing retainer looks like.
Old Jan 20, 2010 | 07:06 PM
suicide67's Avatar
suicide67
ok, wilwood says I have a small ford but i don't know my offset yet till I find some axles
Old Jan 20, 2010 | 07:15 PM
67mustang302
You have to measure your offset. And you have the small Ford bearing, or the big Ford 9" bearing? The retainer is shaped the same, but they're different sizes. You need to be sure, since the caliper mounting bracket on rear brakes bolts to the retainer pattern.
Old Jan 20, 2010 | 08:50 PM
andrewmp6's Avatar
andrewmp6
Try http://www.steeltechsolutions.com/REAR_AXLE_ID.html
Old Jan 20, 2010 | 08:59 PM
Cruzzar's Avatar
Cruzzar
If it came with 28 spline axles, 31 spline axles won't fit unless you tear your rear end gears apart, replace parts and grind out clearance in the carrier. It is almost cheaper to buy a 31 spline rear already set up and sell your original gears in tact. I don't think you can get a 31 spline axle with small bearings, somebody correct me if I am wrong.
Old Jan 20, 2010 | 10:30 PM
suicide67's Avatar
suicide67
the pumpkin has a 3.89 gear 31 spline locking diff, The housing is the small bearing ford 9" rear as I measured as per wilwood specs and the above link. So I can't get 31 spline axles in that housing? Is that what your telling me cruzzar, because I don't have axles right now to check? That would suck
Old Jan 21, 2010 | 02:18 AM
67mustang302
Are you saying it's apart? Or that you don't have axles? If it uses the small bearing then you need to get a small bearing and 31s axles that fit the small bearing.
Old Jan 21, 2010 | 01:48 PM
suicide67's Avatar
suicide67
yes it's apart and I dont have axles
Old Jan 21, 2010 | 10:24 PM
Cruzzar's Avatar
Cruzzar
I guess I learn something new every day. Currie lists a pair of custom axles with studs and small bearing for $460.00. So I stand corrected. Here's a address
http://www.currieenterprises.com/ces...E.aspx?id=1889
Sorry for the scare.
