Differential Cover
Old Jul 25, 2005 | 06:41 AM
markrazz's Avatar
markrazz
Default Differential Cover
where can i find a nice Differential Cover for my 69..i wanna change the fluids and while at it the cover is pretty ugly..anyone>?
Old Jul 25, 2005 | 02:26 PM
69FECoupe's Avatar
69FECoupe
Default RE: Differential Cover
Assuming your car is an original small block car, you should have an 8" (9" if it was a 351 4bbl or larger) rear. They don't have covers, or drain plugs. You'll have to suck out the gear oil or remove the center section to change it.
Old Jul 25, 2005 | 06:47 PM
markrazz's Avatar
markrazz
wow what a hassle..where do i suck it out from..is there a plug anywhere..anyone done this yet>? ty
Old Jul 26, 2005 | 02:42 AM
68COOP's Avatar
68COOP
Yeah, I've added fluid to mine. It is on the pass side, and it is a plug the screws into the hogs head section. To get the fluid out, you will have to hit the parts store for a small pump, but you might just need to add some oil and be all right.
EDIT: I said the plug is on the pass side, but I'm not totally sure which side it is. Sorry, but it is easy to spot once you are under there.
Old Jul 26, 2005 | 03:40 PM
69mach1377's Avatar
69mach1377
You can paint the back side of the diffy and axle tube for better looks.
Old Jul 26, 2005 | 06:06 PM
markrazz's Avatar
markrazz
ya i was just thinkin that..some rustolium black or aluminium will spice it up a bit..
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
