Help!
Old Feb 15, 2010 | 09:12 PM
69 mustang coupe's Avatar
69 mustang coupe
Exclamation Help!
i have a 69 mustang coupe with a vinyl top that one of the owners installed themselves. The vinyl top is not factory. can someone help me remove it properly?
Old Feb 16, 2010 | 09:30 PM
Scott H.'s Avatar
Scott H.
A good body shop will have the chemicals and experience to help you with this. Most likely the top will need to be repainted, and if any trim pieces were used (like the factory did), the holes will need to be closed up (welded or filled).
FWIW, a coupe sure looks classy with a vinyl top.
Good luck,
Scott
Old Feb 16, 2010 | 10:07 PM
69 mustang coupe
Can someone help me remove it by myself no body shop but thanks
Old Feb 17, 2010 | 12:40 AM
Gun Jam's Avatar
Gun Jam
like physically come over and help?
can you tell what its held down with?
-Gun
Old Feb 17, 2010 | 08:20 AM
mortman's Avatar
mortman
Well if I where you i would lift on edge of the vinyl and get a good glue remover and start striping and lifting from there. Like already mentioned you'll likely need to repaint the top. i do things a little different and would pull out my trusty angle grinder and a good 40 grit flap disk and go to work.
Old Feb 18, 2010 | 03:23 PM
69 mustang coupe
I also dnt know how to remove the chrome trim around the window pictures or videos would help thanks
