new guy with fan question
Old Jul 27, 2005 | 03:06 PM
66muscle's Avatar
66muscle
Default new guy with fan question
Hello, I ve decided to join after lurking on the board for awhile. Got a 66 with a stock 289 and auto. Recently I replaced the the water pump with a flow cooler, it replaced the aluminum stock pump that is shorter than the cast iron pump. I learned that after ordering the wrong one. I replaced the hoses and thermostat and all that jazz. The car has a 3 1/2 fan shroud and a five blade stock fan. My Q is that I know for the fan to operate at its' optimum efficiency it should be half in the shroud and half out. The spacer I have behind the fan is to big and the fan is too far inside the shroud, so are there different size spacers to overcome this.
Old Jul 27, 2005 | 04:12 PM
69mach1377's Avatar
69mach1377
Default RE: new guy with fan question
Yes there are shorter spacers to bring the fan in. Try a local speed shop or Jeg's online.
Old Jul 28, 2005 | 12:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
You can also go to a machine shop, and they can chop your existing spacer to any length you wish is about a nano second. Then go to the hardware store and buy the appropriate length bolts with the right threads. See, there is more than one way to skin a cat, huh?
Old Jul 28, 2005 | 01:36 AM
69mach1377's Avatar
69mach1377
Meow...
Old Jul 28, 2005 | 01:40 AM
Jinxed67Stang's Avatar
Jinxed67Stang
a fan question... sure I sign autographs, but no body parts on dudes tho![sm=nono.gif]
Old Jul 28, 2005 | 02:21 AM
Markstang1969's Avatar
Markstang1969
ORIGINAL: Jinxed67Stang
Not even my fender?? [sm=roll.gif]
chain
Aug 17, 2015 08:52 AM
jdphillips73
Aug 16, 2015 04:34 PM
Barcafut13
Aug 13, 2015 08:05 AM
StangMuscle
Aug 12, 2015 07:27 AM
HIS S-197
Aug 10, 2015 05:47 PM
