Control Valve
Old Feb 25, 2010 | 12:55 AM
67 newb's Avatar
67 newb
Default Control Valve
what are the advantages of a 5/16" pressure port vs. 1/4"?
Old Feb 25, 2010 | 01:01 AM
67t5ponycoupe's Avatar
67t5ponycoupe
It is bigger so more fluid goes through. Are you talking about power steering?
Old Feb 25, 2010 | 10:47 AM
stanger53's Avatar
stanger53
They changed it because the smaller 1/4" fittings were easily rounded off or the threads in the housing were stripped.
The early valves had a check valve/restrictor in the return port and the later valves had a restrictor in the pressure port with a hole smaller than pencil lead, so flow at the port was not the problem.
Old Mar 4, 2010 | 12:53 AM
67 newb's Avatar
67 newb
I think the 1/4" fittings were typical for 1960 - 1967. Would there be any complications in going for a 5/16" on my 67?
I was going to send in my core and go for a rebuilt one with the a 5/16" pressure port. And of course a new set of hoses http://www.mustangsunlimited.com/ite...sp?T1=PSHK6+01
Old Mar 4, 2010 | 08:55 AM
stanger53's Avatar
stanger53
Go ahead and get the 1968-1970 valve with the bigger pressure port. Then get a 1968 pressure hose and it will all work.
Don't use a 1967 hose with an adapter because the extra length of the adapter will throw off the fit of the metal part of the hose and cause interference with the ball stud and pitman arm.
Old Mar 5, 2010 | 01:03 AM
67 newb's Avatar
67 newb
hmm.. good tip. I'll look more into that.
thanks
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
