MP Product Overhead Console
Old Feb 27, 2010 | 07:48 AM
sentipede's Avatar
sentipede
Default MP Product Overhead Console
Well, I was bidding on nice overhead console on eBay, but was outbid at the end. Anyhow, I have been entertaining the MP Products consoles, and while not exactly OEM correct, they are $200+ less expensive than the Scott Drake pieces and may serve its purpose.
1965 1966 1967 1968 Mustang Fastback Overhead Console
I was wondering if anyone here had any experience or suggestions with this console. It does not use brackets and the install directions are a little vague....
OVERHEAD CONSOLE INSTALL INSTRUCTIONS
Old Feb 27, 2010 | 05:18 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I see what you mean abou the directions. First they say to drill holes in the roof rail and then say predrilling of the roof rail holes is not needed. It sounds like is would be fairly easy to install though. Screws in the front and back that go into the roof brackets and plug in the wires. If you do the wiring the way they say you will not have a dome light when you open the door. If you have courtesy lights under the dash they will be on all the time too. That problem would need to be fixed.
tmdm
May 2, 2021 02:49 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
