Wrecked my engine
Old Feb 28, 2010 | 11:48 AM
kalli's Avatar
kalli
Post Wrecked my engine
Let the engine warm up as icurrently have no choke. Blasted out of driveway lots of wheelspin car goes sideways in back I left off to switch to second gear and I get a huge knocking noise. It idles but knocks like mad. Drove it back in and left it cool down to check on oil and water. No oil in water and the other way around. It's about 70 miles from home. Girlfriend will drive me back. Next week I'm in German so I won't be able to trailer it back for at least a week. No sign of damage outside. I'm sure I broke something internally. No idea what. I'm so pissed off with myself and car. It was like overrevving it but I have the limiter set for 6200 and tested once at 2500. bollocks
Old Feb 28, 2010 | 12:06 PM
THUMPIN455's Avatar
THUMPIN455
Probably just a rod bearing. Perfect time to drop in a stroker kit. Never look at it as a disaster unless the block has huge holes in it. Knocking rod bearings are an opportunity!
Old Feb 28, 2010 | 01:41 PM
rtintwo's Avatar
rtintwo
Thumpin is right. Perfect time for a stroker kit or to shoehorn a big block.
Old Feb 28, 2010 | 02:04 PM
JDraper's Avatar
JDraper
Ouch..sorry to hear that. Had the same thing with our '66 right after we re-did it. Thankfully ours was only a broken rocker stud. Was a good excuse to go get aluminum heads though
Old Feb 28, 2010 | 02:10 PM
scootchu's Avatar
scootchu
Well that sucks. Time to drop the pan. Sorry to hear that.
Old Feb 28, 2010 | 02:19 PM
Gun Jam's Avatar
Gun Jam
probably a good idea to actually drive it around a bit before smashing on it get everything spinning under load (but im sure you figured that out )
Hopefully an easy fix...how many miles were on that engine?
-Gun
Old Feb 28, 2010 | 07:37 PM
MonsterBilly's Avatar
MonsterBilly
Ist that the engine that you just put in? Deffinatly sounds like a rod bearing!
Old Feb 28, 2010 | 09:51 PM
plainsman1876's Avatar
plainsman1876
Sorry to hear that. I start mine and drive it 10-15 MPH for a while then speed up to 25 MPH 4 a little while then 35 and then 45 until completly warm.then go for it but my 65 FSTBK is a daily driver unless its raining or snowing.
Old Feb 28, 2010 | 10:09 PM
Stepman's Avatar
Stepman
Sorry to hear that. Is it higher pitch or lower knock? Could just be rocker came loose. Hope it's just something simple.
Old Feb 28, 2010 | 10:39 PM
Starfury's Avatar
Starfury
Ugh. My sympathies. But like everyone else has said, you might as well make use of the opportunity...
