tachometer installation problem
Old Feb 28, 2010 | 03:01 PM
blue289's Avatar
blue289
Default tachometer installation problem
I just bought a tach and just wanted to hook it up to check idle speed and set timing. I hooked the black to ground, the red to positive on the battery and the green to - on the coil. I made sure its set for 8 cylinders. When I start the car, its not working. Anybody have any idea what is going on?
Old Feb 28, 2010 | 06:13 PM
scootchu's Avatar
scootchu
Does the needle move at all?
You are right on the wiring.
What kind of Tach?
Are the DIP switches definitely set at their limits for the 8 cyl setting?
Old Feb 28, 2010 | 06:20 PM
1slow67's Avatar
1slow67
ROTM Moderator
Maybe it isn't getting a good enough ground. Your wiring is definitely correct though.
Old Feb 28, 2010 | 10:28 PM
Stepman's Avatar
Stepman
Isn't there a fourth wire? It should be for a light and not matter but...
Old Mar 1, 2010 | 01:20 AM
Silverblade's Avatar
Silverblade
i havent hooked up the white wire for the light yet and it still works fine. check all of the connections again, maybe scuff them clean
Old Mar 5, 2010 | 09:03 AM
blue289's Avatar
blue289
I did not hook up the white wire because it is just for the light. the needle does not move at all. I will try making better connections.
Old Mar 5, 2010 | 02:14 PM
Silverblade
make sure you have it connected to the ground on the coil as well, if you are unsure try both and see if one works
Old Mar 5, 2010 | 02:57 PM
nassaubayman's Avatar
nassaubayman
Is this one of those mini-tachs? I had an 8K mini tach. When idling, the needle didn't move. My Mustang had to be above 1000 RPM before I saw the tach needle move.
Old Mar 8, 2010 | 08:55 AM
blue289's Avatar
blue289
After rechecking connections countless times I exchanged the tach for a different one of the same model. Turns out the first was defective. Now I am trying to get the rpms down to 500 at idle. What do I need to adjust on the carb to lower the rpms?
djbigskrilla
Sep 20, 2022 01:04 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
Pain.
Aug 7, 2015 10:48 PM
