Transmission
Old Mar 1, 2010 | 08:44 PM
1967coupeon101's Avatar
1967coupeon101
Default Transmission
Ok, first off sorry for being all over the place these last few days! for those of you who have seen my previous posts, I am not going with the 351w with FMX. I'm just going to keep the plan of putting in the 289 i already have. I was able to turn the engine by hand today so I'm assuming thats a good sign when it comes to the internals.
now for why I'm creating a thread:
my original plan was to keep the 3speed auto c4 for financial reasons. Now I'm saying F*** it! if I am going through all of this trouble (really my pleasure) to convert to a 8cyl 289, I better get my moneys/times worth! I want a 3 or 4 speed manual, for the sporty feel.
I'm thinking t-10 or toploader.... any suggestions....?
and thanks.
Old Mar 1, 2010 | 10:21 PM
Gun Jam's Avatar
Gun Jam
or a 5 speed for the bad *** feel.
-Gun
Old Mar 1, 2010 | 10:44 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I agree 5 speed is the way to go. You can do is cheaper than a toploader, usually. Top loaders are expensive now a days. Do not go with a 3 speed. You will not be happy. I can't tell you how many times I drove my dad's 3 speed and put it into reverse to go forward at the stop light. They just suck. You can get them dirt cheap though. Saw one on Craig's list locally and the guy wanted $600. I about fell out laughing!! 3 speeds are worth $100 or less.
Old Mar 1, 2010 | 11:27 PM
1967coupeon101
so i should be looking for a t-5, thats what is recommended?
Old Mar 1, 2010 | 11:52 PM
Gun Jam's Avatar
Gun Jam
yes
Look for a world class (WC) not a non world class (nwc) one from a v8 would be best and 1990 to 93 would be best but 83 (i think) to 93 will work.
-Gun
Old Mar 2, 2010 | 03:22 PM
1967coupeon101
ok, found this on craigslist: sounds like a good deal to me. what do you guys think? fair price?
heres the post:
1979-1993 Ford Mustang Complete Borg Warner T-5 5spd Conversion/Changeover
5.0/V8 Setup
Included is
Borg Warner T-5 Transmission
Bellhousing
Blockplate
Shifter
Flywheel
Clutch Setup
Clutch/BrakePedals
Clutch Cable
Driveshaft w/Yokes
Transmission Crossmember
ALL HARDWARE!
This is everything needed to convert your 79-93 AOD Car over to a 5spd Setup
$695.00 for the complete setup
Will Seperate Tansmission for $495.00
Bellhousing $95.00
Crossmember $40.00
Shifter $40.00
Driveshaft $45.00
Flywheel $45.00
Clutch USED $45.00
Cable and Pedals $65.00
Hardware call for specifics
Old Mar 2, 2010 | 03:44 PM
67t5ponycoupe
That is a killer deal. The questions I have are; What year is the trans? They didn't start the World Class T-5 until 86. He says he has pedals but for what year? You will need pedals to fit a 67/68. He says he has a fly wheel but for what? You will need the 28oz imbalance not the 50oz that came with the 5.0 motor. Trans cross member, what year will it fit? You need 67/68 only. The drive shaft may or may not work with your year, you need to figure that out too.
Old Mar 2, 2010 | 03:53 PM
1967coupeon101
thanks a lot, I'll give the guy a call and ask the very questions you posted here
Old Mar 2, 2010 | 04:08 PM
67t5ponycoupe
If it came from a 67/68 you will really be in luck. If it is from a different year there are still a bunch of things that will help. The big thing is the trans needs to be from an 86 to 93 to make things really easy. If there is a tag on the trans have him give you those numbers and we can look up and see what it came from.
Old Mar 2, 2010 | 04:56 PM
jcoby's Avatar
jcoby
will a t5 last behind a 351w? they're only good for 265 lb/ft stock (300 lb/ft for the 90-93).
