Axle condition
Old Mar 2, 2010 | 12:28 AM
67 newb's Avatar
67 newb
Default Axle condition
I was able to pull the hub off the rear driver side and this is my current axle. Is this mostly surface rust that can be removed? What's the general requirements for a rebuild?
Old Mar 2, 2010 | 02:16 AM
1967coupeon101's Avatar
1967coupeon101
just get some sand paper, or a mild grinder, paint it if you like and it'll be good. just make sure you cover the threads on the bolt if you do paint (which there really is no point for on the hub)
if you use the sand paper or grinder and see shiny silver, your all good.
Old Mar 2, 2010 | 02:22 AM
andrewmp6's Avatar
andrewmp6
Wire brush and por15 it but for me i never bothered to paint mine no one will ever see it.The housing and 3rd member i did paint tho.
Old Mar 2, 2010 | 03:17 PM
67 newb's Avatar
67 newb
awesome. I'm glad I don't need to buy new ones. What would be the reasons for new axles though?
Old Mar 2, 2010 | 04:52 PM
jcoby's Avatar
jcoby
broken, twisted, bent, damaged splines, cracked, or the important machined surfaces are damaged (mostly where the bearing and seal goes).
rust, not so much. the exposed bits always rust. they lead a hard life.
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
winner99
Oct 1, 2015 01:06 PM
mdg
Oct 1, 2015 07:04 AM
Sep 24, 2015 09:18 PM
