What oil weight?
So I'm going to begin working on a 1968 Mustang with the inline 6 today. First thing up is going to be the oil. What weight should I be putting in? I know MY stang takes 5w20. Should I go with the same for the 68? Thanks
10w-30 should be fine...
But then you get into the whole mess of running an off the shelf oil with low zinc levels made for modern engine without flat tappets.
The idea is an oil like valvoline VR1 racing oil has high levels of zinc / phosphorus which reduce wear on high friction surfaces such as non roller cams and rockers and the off the shelf oil may not provide adequate protection.... you can also buy a zinc additive to add to an off the shelf oil so it acts like the VR1 oil.
-Gun
-Gun
jar_are_red
Sep 24, 2015 07:03 AM
