adjusting ignition .... again ... !
Old Apr 13, 2010 | 09:52 AM
urban_cowboy's Avatar
urban_cowboy
I know what you are asking MB, but when I was running dead rich at WOT, I had some pinging but with the same total timing, those issues went away when I got the AFR under control.
Old Apr 13, 2010 | 10:47 AM
kalli's Avatar
kalli
Originally Posted by urban_cowboy
Kalli, I had some detonation issues last year that came pretty much from running too rich at WOT. Once I got a handle on the AFR, my detonation issues basically went away. Follow the AFR. It does not lie. Max power is going to come around 12.5-13:1. The best fuel efficiency, for me, is low 14s b/c anything higher causes lean surging. I can really tell when I hit the secondaries because my AFR goes from 14s to 12s and my power kicks in like a nitrous hit. If your all your plugs are firing (a misfire will show a leaner AFR...crazy I know), then make sure your AFR is set right throughout your throttle movement and under load and cruise. Once you have that set, get a friend to drive with you that can hear the pinging and do some WOT pulls. You can increase the timing a little bit at a time and then do another WOT pull. Stop when your friend hears the rattling marbles. IMO, AFR is going to affect your performance MUCH more than a few degrees of timing. I consider timing adjustment, fine tuning.
a misfire will show a leaner AFR...crazy I know--> it is mad, but actually quite obvious as the sensor measures oxygen. If you don't fire you have plenty of fuel coming the sensors way, but all it picks up on is the massloads of oxygen
But since you meantion A/F, I believe I really should go and correct A/F since the timing is what it _should_ be from what everyone seems to say
maybe i just get more power when I advance more because there's too much fuel to burn to begin with ...
Kalli
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
winner99
Sep 30, 2015 07:04 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
