shake rattle & roll
Old Apr 20, 2010 | 07:32 PM
mustang6501's Avatar
mustang6501
Cool shake rattle & roll
Now I can't believe that I am the only one to experience this phemon. Last month I'm out on a very nice day trip when all of a sudden a horrible racket starts from the front wheel. So after removing the wheel cover I find that the bearing dust cap is banging around making this noise. Down to the auto store for new caps and I installed them. Today the same thing happened. What is causing this to happen and is there a cure?
Old Apr 20, 2010 | 09:41 PM
Joe1967's Avatar
Joe1967
did you peen it on or just set it in?
use a broad rubbet mallet with some weight, or a 2x4 and a steel hammer and smash it on till it seats, you'll notice a difference in sound if your usin a block of wood when it seats
Old Apr 20, 2010 | 10:05 PM
JMD's Avatar
JMD
You aren't loosing a wheel bearing are you?
I would at least jack up the car and check for looseness.
Old Apr 21, 2010 | 06:21 AM
MBDiagMan's Avatar
MBDiagMan
Yes, you should check your wheel bearings. When was the last time you greased them. It might be a good time to pull the hub, clean, inspect and grease the bearings. When you're finished, use a drift punch around the edges of the caps to seat them all around.
Old Apr 21, 2010 | 09:55 AM
mustang6501
Thanks for the advice. The wheel bearings have been inspected and repacked about 500 miles ago. I set the cap using a steel pipe with the same diameter as the flange. It may need to be set with a blow to the center portion to increase the tension on the drum. I'll give it a try.
4cylinderplus2
Oct 9, 2020 07:45 PM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
