boss bracing
Old May 2, 2010 | 08:35 AM
6mustang6's Avatar
6mustang6
Default boss bracing
Ok, I was talking to Scott on this bracing and he said someone makes a brace to fit the 65-66 mustangs. it's the one that connects to the lower control arm mounting point. Anybody have a clue? thanks!
Old May 2, 2010 | 02:02 PM
rtintwo's Avatar
rtintwo
If you are talking about the crossmember then this is what you are looking for.
http://www.cjponyparts.com/product.asp?pn=CMF1
Old May 2, 2010 | 02:24 PM
Deviousfred's Avatar
Deviousfred
Cobra Automotive also sells one for 150 I believe.
Old May 2, 2010 | 07:14 PM
67mustang302's Avatar
67mustang302
Yup, that's the one. Not only does it bolt to the frame rails but it ties into the LCA mount, so it's VERY rigid due to the triangulation.
Old May 2, 2010 | 09:02 PM
6mustang6's Avatar
6mustang6
Thanks guys. You are awesome!!!
Old May 3, 2010 | 12:58 AM
andrewmp6's Avatar
andrewmp6
You mean this was http://home.flash.net/~sanco/mustang.htm
Old May 3, 2010 | 06:59 AM
6mustang6's Avatar
6mustang6
No Andrew, I've already read through that and it never mentioned the brace that you guys just showed me. they are talking about reinforcing the shock tower which isnt a bad idea either..
Old May 3, 2010 | 08:16 AM
andrewmp6's Avatar
andrewmp6
Weld in tower reinforcement that's what the boss brace really is.Now over the years its been redesigned and most shock tower reinforcement kits have something close to it.I made my own like that site it does two jobs stiffen and blocks off that cup right there that can hold water and dirt.
Old May 5, 2010 | 12:57 AM
nba1341's Avatar
nba1341
is this a replacement for the crossmember that goes underneath your oil pan?
Old May 5, 2010 | 02:22 AM
67mustang302
Yes. It was used on the Boss in Trans Am racing to tie the LCA mounting locations and front frame rails together into a single unit. The suspension geometry stays more consistent since the LCA mounting location can't move. Combined with the shock tower reinforcements, the suspension stays where it's supposed to.
