engine starting
Old May 6, 2010 | 05:07 AM
tx65coupe's Avatar
tx65coupe
A clear fuel filter is nice. You can see if there is trash in the fuel. It may be that your car needs a new gas tank. They are inexpensive and actually easy to change out. A crappy tank can really cause all kinds of headaches.
I have a clear filter just before the fuel pump and another filter just before the carb.
Old May 6, 2010 | 02:42 PM
1967coupeon101's Avatar
1967coupeon101
thanks kalli, ill give that a try and tx65coupe - the fuel tank is the newest part of the car! thanks though
Old May 7, 2010 | 04:35 AM
tx65coupe's Avatar
tx65coupe
Thats good, at least thats not your problem.
Old May 8, 2010 | 12:50 AM
1967coupeon101
its not junk in the fuel line, the filter is clean and the fuel jets into the carb in a nice solid straight line. I'm assuming it is heat soak/ vapor lock. I'm not sure what to do now, I'll try the phenolic spacer although I dont know what that is or how it'll help.
Old May 8, 2010 | 06:49 AM
kalli's Avatar
kalli
it's a spacer that goes between the carburetor and the intake manifold. some people carv it out of wood or any other material which is heatresistant.
something like that:
what carb and what intake do you have? just need to find the matching one, and make sure its not too tall as otherwise the aircleaner will hit the bonnet
Old May 8, 2010 | 01:32 PM
1967coupeon101
that spacer will help with the car starting? how does that work? how would that keep the fuel cooler so it doesnt boil?
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Spiral534
Oct 6, 2015 04:31 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
