Leaking Drain Plug - Got a fix?
Old May 19, 2010 | 09:30 PM
Ruggertuck's Avatar
Ruggertuck
Default Leaking Drain Plug - Got a fix?
My 66 vert gas tank drain plug has a very small/slow leak - mostly just enough to smell up the garage and a put small spot on the floor. Any fix suggestions that are cheaper than a new tank? Thanks
Old May 19, 2010 | 09:36 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Welcome.
Run it dry, remove the plug and seal it with some pipe dope. Any plumbers supply house should have what you need. Tell them it has to be impervious to gasoline.
Old May 20, 2010 | 06:46 AM
kalli's Avatar
kalli
http://www.gsasupplyco.com/gaethse.html or as oxnard says. petrol rated 'teflon tape' or pipe dope.
Old May 22, 2010 | 09:42 PM
Ruggertuck's Avatar
Ruggertuck
Didn't know there was gas proof tape/dope - will give it a try. Thanks much.
Old May 22, 2010 | 10:01 PM
plainsman1876's Avatar
plainsman1876
You can use Seal it . You can get it at Autozone and it will never leak again
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Emblazoned
Sep 3, 2015 10:45 PM
