Rear end
Old Jun 7, 2010 | 03:10 AM
  #21
tx65coupe's Avatar
tx65coupe
Originally Posted by Gun Jam
Right you are.
But at the end of its run will the OP really be sitting there saying damn if I had 3.20s I could have avoided rebuilding this engine for another 8 months?
And 3300 rpm for 4 miles for 3 minutes and 10 seconds once a week isnt over taxing or over revving the engine by any stretch of the imagination.
And Im not sure if there any truth to this but these V8s just seem to run a lot nicer at 2600 to 3000 rpm than they do at 2000 to 2500 RPM. But Im betting that in many cases they do.
-Gun
I agree, they do run better at the slightly higher RPMs, but while just cruising I prefer to have it lower than that. I drive mine all over the area and am on the highway for 20-40 minutes at a time. Its really nice cruising at 2K RPM with OD. I would prefer to not be turning more than 2500. I defintely do not want to be turning more than 3k at 70.
Old Jun 8, 2010 | 08:24 AM
  #22
SJs 66coupe's Avatar
SJs 66coupe
Originally Posted by JDraper
I'd really recommend the 3.55's. We started with 2.x somethings, went to 3.27's and then went to 3.55's. Much happier with the 3.55's.
Also, if your car has an open rear, I'd highly suggest buying a limited slip 3rd member with the gears already installed. It will make a night and day difference in your traction off the line.
This is the one we have: http://www.cjponyparts.com/currie-3r...-1973/p/CE325/
Couple of questions...if I were to install a rear end such as the one at the link above...is it pretty much like my stock one I am running now?
I know I'd have to change the little gear on my speedo cable but could I use pretty much every thing else?
I'd buy new brake pads either way but I am assuming I could run with my existing drive shaft, brake lines, brake drums, etc, etc ?
Old Jun 8, 2010 | 09:56 AM
  #23
Gun Jam's Avatar
Gun Jam
Yes to all
Old Jun 8, 2010 | 03:19 PM
  #24
JDraper's Avatar
JDraper
Yes to all
What he said...it's a drop in replacement. Very easy to do.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
