Help with Kickdown Installation!
Old Jun 28, 2010 | 05:26 PM
Raman4434's Avatar
Raman4434
Default Help with Kickdown Installation!
I just recently installed a new 4 barrell carb and I had to buy a new throttle cable and kickdown kit from Summit for install. The throttle cable installed fine, but when I went to install the kickdown I was missing the old one so I've got nothing to go off of, which leads me to believe it isn't necessary. I would like to have it either way though. So I connected the lower bracket where the old one was, and I know the top of the cable connects to the carb which is the easy part. The thing that confused me was the bracket in the middle of the cable, that can slide up and down and I can't find a place to mount it. There's nothing on the transmission free now that I already mounted the bottom bracket down there...I really don't know what to do with it now...any help would be appreciated! Thanks.
Old Jun 28, 2010 | 09:33 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Since you are using non stock parts I'm not sure anyone can help you without some pictures.
Old Jun 29, 2010 | 08:51 AM
Raman4434's Avatar
Raman4434
Default Pictures
Alright I will try to post some pictures. I did go to this mustang restoration shop and they sold me a very expensive kickdown rod about 3 feet long and said that would work so I have to try to work that onto the carburetor somehow to see if it will fit.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
