has anyone ever considered doing this?
Old Jul 9, 2010 | 01:28 AM
restomod@16's Avatar
restomod@16
Default has anyone ever considered doing this?
I'm sure someone has thought of this before, but has anyone ever swapped in a modern fuel neck so they dont have to stand and hold it and spill fuel all over while trying to fill up their stang? I know it sucks for me because I can only hold it a certain way to get it to stop from spilling and even then the fuel pump kicks off ever once in a while. I'd like to just place it in the filler neck and let it fill with out me having to hold it in there. Anyone think I can just go down to the local junk yard and find one to use or does anyone know of a specific make/model where this has been done?
Oh and I have a 67 coupe so its not like this fuel neck has to be long at all, quite short actually.
thnx
Old Jul 9, 2010 | 05:17 AM
tx65coupe's Avatar
tx65coupe
What I do to avoid this issue is to ease up on the trigger when its getting close to being full. I hardly ever have a problem anymore.
Old Jul 9, 2010 | 09:15 AM
Gun Jam's Avatar
Gun Jam
you could get a fuel cell and avoid the fill neck all together but bad news if you have lots of stuff in the trunk.
Old Jul 9, 2010 | 10:44 AM
1971mach1's Avatar
1971mach1
Try a different gas station. The newer pump nozzles don't seem to
have that problem as much.
Old Jul 9, 2010 | 11:10 PM
Shrinkdude's Avatar
Shrinkdude
Someone did on another forum.
http://www.stangfix.com/testforum/in...ic,2879.0.html
Seems like a straight forward mod
Old Jul 10, 2010 | 12:50 AM
restomod@16
exactly what i was looking for! thanks shrinkdude!
Old Jul 10, 2010 | 03:06 AM
67mustang302's Avatar
67mustang302
I have thought about putting a new one where the old on is, yes. EVERY TIME I PUMP FUEL!!
Old Jul 10, 2010 | 04:27 AM
tx65coupe's Avatar
tx65coupe
I like that idea. That would be nice. Post back if you make one.
Old Jul 10, 2010 | 08:50 PM
Cruzzar's Avatar
Cruzzar
I actually got a late model filler pipe and cut the guts out of it and inserted it into the filler neck for my '70. Here's some pics.
Here's a late model filler neck
Uploaded with ImageShack.us
I cut out just the trap door "guts'
I sliced my stock "70s neck in half, ground the trap door's diameter down to just fit into the filler tube.
And then welded it back together.
Old Jul 11, 2010 | 09:14 AM
65rangoon's Avatar
65rangoon
ive never had an issue filling up and spilling ...
just kneel down, listen for when the gas is hitting the filler neck and start slowing down the flow.
watch in the tube and you can see if coming up.
... i mean you do know the gas nozzle has a variable output pending how much you squeeze right and that its not just off or full blast ....
i kid i kid
