Violent Jolt When Going From Park Into Drive Or Reverse
Old Jul 10, 2010 | 05:56 PM
EnglishJ's Avatar
EnglishJ
Default Violent Jolt When Going From Park Into Drive Or Reverse
I have a 70 Mach 1, FMX auto transmission and there is a violent jolt when I go from Park into drive or reverse, it's worse when the car is warm, ie it doesn't happen when i'm reversing the car out of my garage, apart from that the gears shift great when driving, there is no knocking or delays when going through the gears, i've currently got the car booked in with a Mustang specialist as I had to have the carb rebuilt, but any ideas what the problem could be, do you think the transmission could need rebuilding? I sure hope not, we've got a new modulator valve on order as that is the cheapest option at the moment, thanks for any help
Old Jul 10, 2010 | 07:45 PM
Randys66gt's Avatar
Randys66gt
FMX's have a problem with the pressure valve sticking in the pump. It's due from lack of fluid changes. If all else is ok, you can drive it that way but it will need a rebuild soon.
Old Jul 11, 2010 | 06:35 PM
Aussie66Fastback's Avatar
Aussie66Fastback
if your idle is set too high that will contribute.
if there is excess wear in the diff that will also cause a bit of a bang as the box spins the driveshaft and it takes up the slack. you can get an idea of this by jacking the rear and moving a wheel while the car is in park to see how much play is present. if you have an open diff you'll need to leave one wheel on the ground or chock it.
Old Jul 14, 2010 | 04:08 PM
EnglishJ's Avatar
EnglishJ
Ok thanks for the replies
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
