water leak
Old Jul 19, 2010 | 10:20 AM
marlon1's Avatar
marlon1
Default water leak
got caught in my first rain storm friday in the '66 coming back from a cruise-in
have a serious waterleak on the drivers side was running in from the dash area
what are the main areas to start looking for the leak Thanks for the info
Old Jul 19, 2010 | 10:31 AM
kalli's Avatar
kalli
check the cowl first of all (the vent between hood and windscreen)
pour water down there and if that comes out on the inside of the car, the coal might be rusted through. use either a waterhose or a bucket of water. maybe it's just blocked and water sits in there rising over the air intake.
Old Jul 19, 2010 | 10:53 AM
marlon1's Avatar
marlon1
thanks I've looked at the pan under the cowl, looks like it was replaced when we were
redoing the car. is there a drain line or overflow to the pan
Old Jul 19, 2010 | 11:00 AM
nba1341's Avatar
nba1341
Check cowl first then dumb water the windshield and check seal from corner to middle. Mine leaked from the corner and traveled to above my radio very slowly.
Old Jul 19, 2010 | 11:01 AM
chris66dad's Avatar
chris66dad
Here is a write up and pictures when I checked my cowl tophats. You will get a good idea of what is inside from the pictures.
http://chris66dad.tripod.com/id18.html
Good Luck and BE Safe
Ron
Old Jul 19, 2010 | 11:49 AM
Gun Jam's Avatar
Gun Jam
If the cowl test good the leak is from the body seams. These seams were covered with a seam sealant and over 40 years time it cracks and allows water to run into the car.
The fix is easy...I wonder if I can find that thread...
https://mustangforums.com/forum/clas...oval-help.html
Do that
-Gun
Old Jul 19, 2010 | 08:22 PM
tx65coupe's Avatar
tx65coupe
I agree its probably a leak in the cowl or it could be the vent that is leaking.
I suggest getting one of these cowl covers. I have this one, its the best one I have seen. My car leaked at the vent before, but I think we have that fixed. I use this if the car is parked under trees etc when a bunch of leaves are falling or if it might be stuck in the rain. I keep it in the original box in the trunk. It works well. Even if you get the leak fixed, it can prevent future problems.
http://www.cjponyparts.com/product.asp?pn=CC1
Old Jul 20, 2010 | 08:27 AM
marlon1's Avatar
marlon1
thanks for the info guys, looks like a project for this winter. I'll try to stay out of the rain till then. was going to replace the passenger door & pull the motor to have the block painted this winter anyway, so just one more thing on my list
Old Jul 21, 2010 | 12:15 PM
djsprinklesnjo's Avatar
djsprinklesnjo
i hate it when i wash my car and water gets down into the cowl. its just unnecesarry water getting into places that could eventually cause rust. ive seen cowl covers before but the one you posted tx65coupe is clean looking and cheap. thanks so much. ill be getting one of those soon. anyone have experience with these covers how do they attached, ive never seen one in person
Old Jul 22, 2010 | 05:32 AM
tx65coupe's Avatar
tx65coupe
They have spring loaded tabs that go between the cowl louvers. You press them down and turn them. Its really pretty easy to do.
I agree I want my car to look its best and like to wash it but dont want the water getting down into places that can cause rust. I wash it once a month and thats usually enough since its not a daily driver.
If you get that one, do like the instructions say and keep the box. It will keep the neoprene gasket from getting screwed up.
