Ignition or Carburetor
Hey, whats up guys. I have a bit of a dilemma here. I only have enough money to get either a new electronic ignition system, or I can get a new carburetor. Which of these should I get first? The winters coming soon, and i'm looking for reliabilty. Whenever its like 30*, my car takes forever just to get a good idle. What would you guys suggest is the most important upgrade out of the two for this situation?
Yea, I was thinking about that carb. So you would suggest the carb first over the ignition? Thx by the way
Hey, what CFM would you guys suggest. My cars a daily driver, and I only race when I'm tempted. I'm thinking about the Holley Street Avenger.
If I were you, I'd just get a set of Pertronix for around 60/75 bucks, and you will see a big difference on starting and power. Do you have a 2bbl or 4??? Rebuild kits are about the same as the pertronix, I THINK, so you cou7ld do both for around the price of 1. Someone chime in if I am wrong.
If gapped correctly, they should last a year or more, even longer I guess. Usually you do the points, condenser, and plugs all at once, whenever you do your tune-up. Look down the carb, and if you only have 2 holes, it's a 2bbl, and 4 for a 4bbl.
