390 build
Old Aug 29, 2010 | 02:01 PM
dterry68's Avatar
dterry68
Default 390 build
I've been working on putting a 65 390 in my 68 mustang and wanted some advice on performance parts. I'm looking to build up the 390 to be a street motor but can also take it to the strip. What would be a good first step into the building process?
Old Aug 29, 2010 | 06:18 PM
67mustang302's Avatar
67mustang302
What performance goal, how much money are you willing to spend? Do you have a trans a suspension that will handle it? Chassis strengthening?
Old Aug 29, 2010 | 10:31 PM
dterry68's Avatar
dterry68
i want to try for at least 500hp. I dont have to do it all at once im trying to get parts when i can and have everything together at the end so i can put it all together. i'm workiung on strengthening and i'm getting ready to get heavy duty suspension.
Old Aug 30, 2010 | 01:05 AM
67mustang302
Suspension, chassis reinforcement, transmission, differential, stock internals should hold it, but I'd use good pistons. Good heads(or cleaned up and slightly ported stock heads) hydraulic roller cam conversion(custom grind), matching intake yadda yadda. About $20,000 later(or more) you'll have a reliable 500hp street car.
Old Aug 30, 2010 | 02:46 AM
andrewmp6's Avatar
andrewmp6
You can get 500hp from a small block with half the weight.If you really want a big block forget the fe a 429/460 can be stroked a lot more and can make a lot more power.But power takes money i would start adding up everything see how much its gonna take first.
Old Aug 30, 2010 | 03:37 AM
67mustang302
650cid or gtfo.
Old Aug 30, 2010 | 06:47 AM
voodoojl's Avatar
voodoojl
Default Check out the FE Forum
Network 54 FE Forum
One of the best Ford engine building sites on the net!
Old Aug 30, 2010 | 04:42 PM
dterry68's Avatar
dterry68
well i was going to try and find a 460 but the 390 came at that time and at a great price. it was complete along with a c6 transmission.
Old Aug 30, 2010 | 10:36 PM
andrewmp6's Avatar
andrewmp6
Make sure its a fe not a ft the ft is a truck engine they used different motor mounts.
Old Aug 31, 2010 | 10:37 PM
dterry68's Avatar
dterry68
Yeah its a fe motor it came out of a car i made sure to check before i went and got it.
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
rksnow1
Sep 14, 2015 08:46 PM
