is a 4 valve 289 a A code or K?
Old Aug 12, 2005 | 10:50 PM
skiprCH's Avatar
skiprCH
Default is a 4 valve 289 a A code or K?
Hi all,
In another post I asked a dumb question. My real question is can a 2 valve 289 C code be made into a 4 valve motor? Also is the 4 valve 289 the A code or K code? What is the difference other than more horse power?
Thanks, Walt
Old Aug 12, 2005 | 11:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: is a 4 valve 289 a A code or K?
ORIGINAL: skiprCH
Hi all,
Thanks, Walt
Walt, I think you mean is can a 2 venturi carburated C code engine be made into a 4 venturi carbureted engine. The answer is yes. You have to change the 2 venturi intake manifold to a 4 venturi manifold and add a 4 venturi (barrel) carburetor. The biggest difference between the C code engine and the A code is primarily the 4 barrel carburetor with a 4 barrel intake. The K code gets into the internal parts of the engine with several upgrades.
Old Aug 13, 2005 | 10:59 AM
skiprCH's Avatar
skiprCH
V=venturi now I get it. I thought that 4V was 4 valve. [sm=lol.gif] Now I'm not so confused as to make my 289 a A code. What did they do on the Ks to get more HP? Higher compression pistons and cam?
Thanks, Walt
Old Aug 13, 2005 | 11:57 AM
dodgestang's Avatar
dodgestang
K code = solid lifters, cam, intake?, head work to support the solid lifter cam., hipo manifolds
Old Aug 13, 2005 | 12:04 PM
69mach1377's Avatar
69mach1377
4 valves per cylinder is a relatively recent development for production cars...beginning in the 90s IIRC.
Old Aug 17, 2005 | 03:44 AM
Mustangood's Avatar
Mustangood
a code also upped compression i believe
Old Aug 17, 2005 | 06:28 AM
66 Hardtop 5.0's Avatar
66 Hardtop 5.0
ORIGINAL: Mustangood
You`re right. This is copy/pasted from "FordClassics.com":
1964 1/2 Mustang
A choice of four different engines.
170 c.i. @ 105 h.p. w/9.1:1 compression and a one barrel carburator.
260 c.i. @ 164 h.p. w/8.8:1 compression and a two barrel carburator.
289 c.i. @ 210 h.p. w/9.0:1 compression and a four barrel carburator.
289 c.i. @ 271 h.p. w/10.5:1 compression and a four barrel carburator.
1965 Mustang
200 c.i. @ 120 h.p. w/9.2:1 compression and a one barrel carburator.
289 c.i. @ 200 h.p. w/9.3:1 compression and two barrel carburator.
289 c.i. @ 225 h.p. w/10.0:1 compression and a four barrel carburator.
1966 Mustang
1967 Mustang
A choice of five different engines.
289 c.i. @ 225 h.p. w/9.8:1 compression and a four barrel carburator.
390 c.i. @ 320 h.p. w/10.5:1 compression and a four barrel carburator.
Old Aug 18, 2005 | 12:28 AM
skiprCH's Avatar
skiprCH
Howdy,
I thought the C code was 210 hp?
Walt
GimpyHSHS
19
Dec 19, 2023 01:12 PM
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
Dathan
Oct 5, 2015 05:52 AM
