4 Barrel
Old Aug 31, 2010 | 12:21 PM
chip_127's Avatar
chip_127
Default 4 Barrel
Hey guys. I just purchased a 66 coupe last weekend and am in the process of deciding on what to do to it first. Well last night during a quick spin I noticed that the 4 barrel carb is not opening the two back butterflies. Can someone point me in the right direction on how to fix this? The linkage and everything looks good, and I can open them manualy, but it will not do it while running (on it's own).
Thanks!
Old Sep 1, 2010 | 01:18 AM
tx65coupe's Avatar
tx65coupe
What type of carb is it? Does it have mechanical or vacuum secondaries?
Old Sep 1, 2010 | 03:59 AM
kalli's Avatar
kalli
as tx65coupe suggests, if they are vacuum secondaries then you don't want them to open when you rev the engine out of gear. only if there's actual engine load.
if unsure tape a little string to the secondary linkage, floor it down the road. you will see then if they opened at some stage
Old Sep 1, 2010 | 07:00 AM
chip_127's Avatar
chip_127
I think it's the stock carb. I have not found any type of markings on it to tell what brand it is. It does have vacuum secondaries.
Thanks for the tip. I will take it for a spin this afternoon and try the string trick!
Old Sep 1, 2010 | 08:17 AM
kalli's Avatar
kalli
ya. vacuum secondary need actual engine load to open. if you can open it by just reving in park, _then_ there's somethign wrong. make sure you're not blocking anything. just attach something ever so slight that will fall off when opening.
somethign that can't block your carb or linkage
Old Sep 1, 2010 | 08:20 AM
mr_velocity's Avatar
mr_velocity
Post a pic, these guys will know right away what carb you have.
Old Sep 1, 2010 | 10:24 AM
stephen.osborne1's Avatar
stephen.osborne1
If there are any markings saying "4200" on it, I'll trade you...
Old Sep 2, 2010 | 06:58 AM
chip_127's Avatar
chip_127
I'll try to get a pic of it and post it on here.
Is the 4200 the stock carb that came on the 289 Hi Po?
Old Sep 2, 2010 | 10:25 AM
kalli's Avatar
kalli
i never heard of a 4200 ?! looking for an autolite 4100 maybe? The A-Codes came with a 480cfm (1.08) autolite 4100 and the K-code with a 600-ish cfm (1.12) autolite 4100 I believe
Facetolaw348
Nov 23, 2004 05:35 PM
Mustangdemon67
Nov 10, 2004 01:54 PM
RAdams
May 13, 2004 10:23 AM
