high speed stall out HELP!
Old Sep 3, 2010 | 01:52 PM
killaguerilla's Avatar
killaguerilla
Default high speed stall out HELP!
1972 w a 302, 650 street avenger carb, headman headers w/ dual exaust, new plugs wires, fuel filter, good spark, smooth idle, lots of power off the line and around town, but when I hit the freeway around 60 -70 mph, it stalls out, slow down and she fires back up, only at high speed does she studder then stall, any Ideas what to fix next?? any help or advise would be helpfull thanks
Old Sep 3, 2010 | 04:14 PM
Gun Jam's Avatar
Gun Jam
fuel pump is not delivering adequate pressure and or volume.
Check fuel filter and replace. (looks like you may have covered that)
If problem continues replace fuel pump.
If you would like to test the fuel pump remove the fuel line from the carb and place it in a glass jar. Crank the engine over for maybe 2 or 3 seconds. There should be at least a cup of fuel in the jar and it should surge out rapidly. IF there is only a little fuel and is leaks out of the hose then if the fuel line is not obstructed the pump is bad.
-Gun
piotrek53
Oct 13, 2015 06:54 PM
trashxtrash
Sep 20, 2015 10:49 PM
Sep 8, 2015 11:50 AM
