mechanical solid roller cam in 69 block
Old Sep 16, 2010 | 04:59 PM
GT350son's Avatar
GT350son
Yeah I'm gonna decide to go with a hydraulic cam. And if i'm guess right a 351w non roller block cam will fit in a 302?
Old Sep 16, 2010 | 05:03 PM
GT350son's Avatar
GT350son
Originally Posted by Gary H
It would be cheaper to by a roller block :-)
Do alot of research, some use a smaller base circle cam. So you cant use just any roller cam out there. The crane kit uses a regular cam, but $450 a set lifters.
What are your goals?
Gonna make it my street/strip car but mostly strip. high 400 low 500 hp.
Old Sep 16, 2010 | 05:56 PM
67mustang302's Avatar
67mustang302
What block is this? A 351 or 302 block?
Old Sep 16, 2010 | 06:28 PM
GT350son's Avatar
GT350son
302 that i'm stroking to 347
Old Sep 16, 2010 | 06:58 PM
Gary H's Avatar
Gary H
302 and 351w cams will interchange.
Good luck getting that much HP. Unless you boost or spray it, it's not that easy. What heads etc?
Old Sep 16, 2010 | 07:15 PM
GT350son's Avatar
GT350son
dart 195 cc heads, scat 347 rotating assembly, edelbrock air-gap, holley 650dp, bbk equal length headers
Old Sep 16, 2010 | 07:28 PM
Gary H's Avatar
Gary H
Decent combo, but it's not going to make the HP goals you want. I'd guess about 400 at the flywheel depending on cam and compression. Before you get a cam, talk to some of the cam companies and see what they recomend for what you have.
Old Sep 16, 2010 | 07:37 PM
GT350son's Avatar
GT350son
What would you suggest for a low 500s hp 347 on pump gas?
Old Sep 17, 2010 | 04:24 AM
67mustang302
Bitchen high dollar heads for starters. Like some TEA ported TFS TW heads, with a LIGHT rotating assembly. Custom cam, probably more like a Vic Jr intake, and at LEAST a 750cfm carb. And you'll prolly be turning 6,500rpm, maybe more.
Old Sep 17, 2010 | 07:01 AM
Gary H's Avatar
Gary H
^ What he said. Other heads would be the AFR 205-225 and the edelbrock victor jr's. And then you're looking at the limits of the stock block.
What ET's do you want to run with the car?
some ideas
http://www.airflowresearch.com/ford_dyno.php
