What Primer to use?
Dupont DTM Zinc Chromate Epoxy 2580CR, right around $200 a gallon plus activator right around $180. I believe its been discontinued.
Not sure what replaced it.
http://pc.dupont.com/dpc/en/US/html/...eet/2580cr.pdf
I've used this primer for years in marine applications, lots of salt water, never having corrosion issues.
Not sure what replaced it.http://pc.dupont.com/dpc/en/US/html/...eet/2580cr.pdf
We've used ppg omni on the bottom, which we will then use U-pol Raptor as the final coat.
We will be using SPI on the rest of the body...
http://www.southernpolyurethanes.com/SPI%20News.htm
I have bought the 2580 within the last 2 years, I think I still have 1/2 gallon or so.
Why not OMNI? I think it is the cheaper line made by PPG. I back it with the argument that the industry is so competitive that a crappy product would not survive, yet OMNI marches on. Just read the spec sheets and make sure your build primer and or paint will mate with it. Buy a quart and a pint of activator and spray a sample piece and see how you like it, maybe let it sit for a week and try to sand it or what ever, if you don't dig it, go spend three times as much on something else.
Here it is in action: https://mustangforums.com/forum/clas...ed-roof-6.html
In my experience, most any "good" product is interchangable among different brands so long as it is sanded to a good tooth for mechanical adhesion
Same goes for the results, what some people consider acceptable others will consider crap. There how many threads about getting a "decent" paint job using spray cans?
For me, unfortunately my skills don't match up with the quality of the product I'm using
