Need help choosing rear ends
Old Oct 16, 2010 | 12:19 PM
Michaelsgirl's Avatar
Michaelsgirl
Default Need help choosing rear ends
Which vehicles offer rearends to fit a 66 mustang to make it a 5 lug? I hear explorers work, but needs to be modified. Is there a rear end out there that will fit right?
Old Oct 16, 2010 | 12:34 PM
Randys66gt's Avatar
Randys66gt
This might help you out.....
http://www.ridgenet.net/~biesiade/Fordrears.html
Old Oct 16, 2010 | 10:36 PM
andrewmp6's Avatar
andrewmp6
64-66 8 inch will bolt right in watch craigslist for a v8 car parting out.Or even the classifieds on here for one.
Old Oct 17, 2010 | 12:27 PM
Michaelsgirl
Thanks..Is there a newer model car that may be a good donor car? also what about a 72-73 nova rear end? will that fit?
Old Oct 17, 2010 | 04:33 PM
Randys66gt's Avatar
Randys66gt
Anything can be made to fit. The 68-74 Nova had a width of 60.25" so it's over 3" wider. 95% of the Nova's came with a 10 bolt and it would be easier to find an 8" or 9".
Here's another one for you.
http://www.carnut.com/specs/rear.html
Old Oct 17, 2010 | 04:39 PM
001mustang's Avatar
001mustang
I would look for 65-66 mustang 8" like andrew said. I am running 8" w/ 351W and it seems to be holding up. 8" behind a 289 will last decades. 8" is cheap, easy to rebuild, and can change ratio easily.
Old Oct 18, 2010 | 12:14 AM
andrewmp6's Avatar
andrewmp6
The nova is the wrong bolt pattern for the wheels and probably too wide by guessing.There is really not anything new that will bolt in and fit perfect.The 8.8 from the explorer will fit but the diff is off centered if lower it can cause problems beating the floor pan.You can get a 64-66 8 inch from http://www.perogie.com/Rears.htm but shipping a rear end might be high.I would place a wanted to buy add on craigslist and on here for the rear end you need.Most who swap to a 9 inch will almost give away a 8 inch to get out of there way.
Old Oct 18, 2010 | 11:30 AM
Michaelsgirl
Thanks guys..that helps.. this is my first project car and I want it to kick ***..My husband is helping me a little but he is a chevy guy..lol We have a 57 chevy pickup, 1970 nova, my 66 mustang, and a dropped 86 chevy shortbox. as well as our 4 daily drivers..But i'm only working on the mustang, while he tinkers with the other projects. I dont think he thinks I can do it, so I'm trying to get as much help as I can from people who know mustangs. Thanks again..I will let everyone know how its going once I find a rear end.
Old Oct 18, 2010 | 12:15 PM
001mustang's Avatar
001mustang
If you get an 8" or 9" there are nice how to videos such as bad shoe productions.
8" is exactly like 9" except smaller and specs are slightly different; rebuild technique is the same.
If rear end oil looks good w/o metal flakes, no vertical play, rotates smoothly, no signs of oil leaks at seal; you can probably just plug and play.
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 8, 2015 11:50 AM
