air cleaner snorkel thingey
Old Aug 17, 2005 | 11:15 PM
nualln's Avatar
nualln
Default air cleaner snorkel thingey
When I bought my mustang, the previous owner kept the old air cleaner with a snorkel. It's a big blue cleaner with a snorkel on the end of it, and then this peice that I have no Idea what it does. It seems to go inside the bottom of the snorkel and take the air from somewhere else.
It's the thing this guy is painting in the pic:
So what is it, where does it go?
Old Aug 18, 2005 | 07:15 PM
6mustang6's Avatar
6mustang6
Default RE: air cleaner snorkel thingey
Thats the heat shroud. I have one for mine, but the bolt that holds it on the manifold is broke off inside. It was like that when i got it. KEEP it because it is a $70 part. But it connecys to the air cleaner and bolts up to the passenger side exhaust manifold. Hope this helps.
Old Aug 18, 2005 | 07:29 PM
nualln's Avatar
nualln
What is the purpose of it?
Old Aug 18, 2005 | 07:31 PM
6mustang6's Avatar
6mustang6
Well, i never quite figured that out. I guess to heat up the air going into the carb in the winter.
Old Aug 18, 2005 | 10:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
That is to add hot air from your manifold to your carburetor to activate your automatic choke mechanism. The hotter your manifold gets, the more your choke mechanism will open.
Old Aug 19, 2005 | 07:00 PM
6mustang6's Avatar
6mustang6
I dont have mine on there, and my choke opens up fully after it's warmed up. It's not a something you really need.
Old Aug 20, 2005 | 04:18 AM
Soaring's Avatar
Soaring
I ♥ Acer
If you want the automatic choke to open at factory specs you need it. Yes, your choke will open from surrounding warm air sources, but not as efficiently as with this guy.
Old Aug 20, 2005 | 09:56 AM
69FECoupe's Avatar
69FECoupe
You are correct as it has little to do with the choke. To operate the choke most old Fords have a 5/16" choke "stove" connection tube that goes to the exhaust manifold and/or one of the heater hoses in a bracket next to the choke coil. The main purpose of the heated air pipe was to help prevent carburetor icing and to get the motor up to operating temperature quickly.
Old Feb 18, 2009 | 09:49 AM
ChesterKaup's Avatar
ChesterKaup
Should a 1966 289 2v without California emmissions have one of these?
Old Feb 18, 2009 | 10:11 AM
Nick.Simonds's Avatar
Nick.Simonds
Why don't you make you own post so people will see this. This thread is 3 years old...
