Rear brakes locked.
Old Nov 9, 2010 | 01:13 PM
Stang 65's Avatar
Stang 65
Question Rear brakes locked.
Hey all,
I just took my 65 mustang out of the garage for the first time in about a year and a half. We noticed the rear wheels were not turning. I assume the the rear brakes are locked up. If so what is the easiest way to free them up. Need to put it back in before winter. The e-brake is not on.
Old Nov 9, 2010 | 02:36 PM
69mach1377's Avatar
69mach1377
Turn the shoe adjuster and/or open the bleeds?
Free bump
Old Nov 9, 2010 | 02:39 PM
001mustang's Avatar
001mustang
If both are locked up the maybe master cylinder residual pressure valve, prop valve, etc. is holding pressure.
I would bleed both wheel cylinders of pressure.
I would adjust both shoes to full loose.
I would verify that e brake cable is not sticking.
If drum won't come off after best effort you can grind ends off of shoe pins.
Old Nov 9, 2010 | 08:16 PM
rtintwo's Avatar
rtintwo
If it as me i would just pull the wheels off and bang on the drums some to loosen them up. its probably the drum surface getting a bit of rust on them from sitting and causing the shoes to grab. After the drums come loose then take some sand paper to them to clean them up. There is no use over thinking this until you know its not something simple like rust.
Old Nov 9, 2010 | 09:27 PM
001mustang's Avatar
001mustang
Would both rear tires will skid if car is pulled w/ a chain???
Or are you just turning them by hand???
I have seen a car that was outside for many years where one tire would skid.
On that car the brake shoe practically welded itself to the drum.
Was able to loosen by removing wheel, putting lug nuts on half way, Taping a pry bar (positioned between lugs) w/ sledge and also taping drum w/ sledge.
Since your car was in garage and both rear wheels are frozen I thought that the shoes are swollen from leaked fluid or pressure is built up in rear line or e brake not releasing.
Old Nov 10, 2010 | 08:38 AM
Stang 65's Avatar
Stang 65
Yes both tires skid when it was pulled out of the garage.
Old Nov 10, 2010 | 11:03 AM
001mustang's Avatar
001mustang
Adjust shoes by pushing tool up (against the ratchet effect); should push ratchet bracket out.
Likely only have to bleed pressure off only one rear wheel cylinder.
If you get frustrated getting those succas off it may be easier to grind heads off shoe attachment pins. Stop grinding when head weakened then punch pins thru hole. Have spare pins in hand before grinding.
Sometimes you have to get a lil firm w/ da sledge. I don't like to beat car too much; many say it wont hurt.
Can use torch w/ rosebud if you are very careful not to over heat; good judgment required..
I never seem to have luck w/ penetrating oil but I let it soak none the less.
If drums have a lot of miles they may need replacing. New drums are pretty cheap these days. Another option is to cut drums and replace.
Last edited by 001mustang; Nov 10, 2010 at 01:03 PM. Reason: 67t5ponycoupe adjustment correction
Old Nov 10, 2010 | 12:07 PM
67t5ponycoupe's Avatar
67t5ponycoupe
To de-adjust the shoes you have to take a wire and move the self adjuster out of the way and move the tool up not down.
Old Nov 10, 2010 | 12:26 PM
001mustang's Avatar
001mustang
You are correct.
Old Nov 10, 2010 | 11:24 PM
67t5ponycoupe
If you let the car sit with the park brake on I would get under it and ensure the park brake is actually released before trying anything else. I doubt that it is a hydraulic problem.
mtgldr
Feb 3, 2024 09:00 PM
Galactic
Apr 29, 2019 02:56 PM
musnicki
Sep 23, 2015 07:11 AM
DoctorScary
Sep 9, 2015 07:53 AM
