Wheel adapters, new studs needed?
Old Nov 9, 2010 | 06:58 PM
Sixty7RestoCoupe's Avatar
Sixty7RestoCoupe
Default Wheel adapters, new studs needed?
Hey everybody, just recieved my 1.5 adapters from ebay today for my 06 bullitts wheels. I know its a pretty common conversion but my concern is the stock stud length. Theres still thread on the nut but the stud isnt long enough. Is this right?
Old Nov 9, 2010 | 10:05 PM
Iskwezm's Avatar
Iskwezm
i would try a short shank open end lug nut
Old Nov 9, 2010 | 11:57 PM
guitarman376's Avatar
guitarman376
I recognized that the rear studs are not very long when I put 1.5" wheel adapters on my car. Literally checked today with a torque wrench and they haven't loosened at all. I would probably get longer wheel studs if I was going to the race track anytime soon, but my car is street driven only at the moment. The fronts were perfect for me, after doing the 13" cobra conversion that came with new hubs
Old Nov 10, 2010 | 12:18 AM
TexasAxMan's Avatar
TexasAxMan
I have to say that I don't think wheel spacers are very safe at all. Judging from the pictures, you don't have enough thread left to run those safely. You should have threads protruding from the stocker lug nuts. Please don't run those ....
Old Nov 10, 2010 | 07:43 AM
ozarks06's Avatar
ozarks06
It looks like you have only about half the threads on the nuts making contact. I wouldn't use them that way (and personally wouldn't use adapters on the rear at all).
Those wheels do look nice.
Old Nov 10, 2010 | 08:10 AM
kalli's Avatar
kalli
unsafe as it is. maybe with shanks. as above.
i wouldn't even use those nuts as there is no way to make sure the spacer is sitting right
contact manufacturer to provide safe solution
Old Nov 10, 2010 | 09:17 AM
Norm Peterson's Avatar
Norm Peterson
Can't see the pictures. Don't like spacers to begin with.
If you don't have thread engagement at least equal to the lug diameter, you're asking for trouble. Thread engagement equal to only half the lug diameter is like jumping up and down begging for it.
Can't tell how much thread engagement you really have? Don't drive the car until you know that you have at least one diameter's worth. This is not a place to cut corners. Replace with ARP.
That the torque has not relaxed may not be a good enough indicator that the thread engagment that you do have hasn't been yielded slightly. If that sounds like a bad thing, it sounds about right.
Norm
Old Nov 10, 2010 | 10:44 AM
5'Oclocksomewhere's Avatar
5'Oclocksomewhere
I agree with this.
If you are going to go with spacers (which I never would..) atleast do everything in your power to make sure they are bolted on correctly. Check parts stores for other length studs.
Old Nov 10, 2010 | 11:46 AM
jspagna1's Avatar
jspagna1
NOT SAFE!!!!!!
If they were 1" spacers, you would be alright but that extra 1/2" is killing you.
You are suposed to be able to get like 8 turns with the lug nut on the stud for it to be safe and I would suspect you are nowhere near that!
Call the manufacturer.
Old Nov 10, 2010 | 12:03 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I ran into the same problem when I was running 05 bullitts. I changed all the studs, at $2.50 a stud that adds up quick. That is the safe way to do it. With a 1/2 inch stud you should have atleast 1/2 inch of lug nut on the stud and if yours are like mine were then you will be very close to that. I don't have a problem running spacers like some fols do. I think they are safe but need to torqued properly, they are lug centic so they center themselves when torqued.
