Pulling the motor
Old Dec 20, 2010 | 09:45 PM
p4lm3r's Avatar
p4lm3r
Default Pulling the motor
Again, please forgive me for being a nub, but where do you attach the engine crane when pulling the motor? I know this is probably a no brainer, but I work mostly on european cars. Thanks!
Old Dec 20, 2010 | 09:47 PM
p4lm3r's Avatar
p4lm3r
Since I can't figure out how to edit a post, this is a 1970 Mach 1 H code.
Old Dec 20, 2010 | 09:53 PM
mikenkiki05's Avatar
mikenkiki05
ive always used the lift plate that bolts where the carb bolts to intake, i always buy the adjustable liftplate that has 3 holes in it
Old Dec 20, 2010 | 09:57 PM
CyprusMustang's Avatar
CyprusMustang
you can do what mike says or you can use a couple of brackets, attach one to the front header somewhere and the back to a transmission bolt but make sure your doing it diagnally though.
Old Dec 20, 2010 | 10:11 PM
mikenkiki05
http://www.speedwaymotors.com/Engine...ates,2923.html
thats the style i have used the one i have it a tad different now
Old Dec 20, 2010 | 11:36 PM
p4lm3r's Avatar
p4lm3r
Thanks again, everyone!
Old Dec 21, 2010 | 01:15 AM
andrewmp6's Avatar
andrewmp6
I use a load leveler which looks like this http://www.amazon.com/4000-Leveler-E.../dp/B001P5UWUW i bolt it on the intake bolts on the 4 corners.Its great if your pulling the engine and trans together or engine by yourself.
Old Dec 21, 2010 | 07:15 AM
mr_velocity's Avatar
mr_velocity
+1 on the load leveler. Makes going back in a lot easier too.
Old Dec 21, 2010 | 12:20 PM
crunchyskippy's Avatar
crunchyskippy
Can you use a carb lift plate on an aluminum intake to lift the engine?
Old Dec 21, 2010 | 06:22 PM
JMD's Avatar
JMD
If you have a welder and $5 worth of 1/8" plate you can whip up a plate to fit the manifold in no time.
An aluminum maniflld should be more than strong enough, even the imported re-pops should be good enough.
