1969 351W starting problem
Old Feb 10, 2011 | 11:56 PM
cougar70's Avatar
cougar70
Default 1969 351W starting problem
I picked up my 69 coupe from the body shop, it fired right up, and i drove it across the street to the gas station to put gas in it. When I tried to start it up again, every time I turned the key there was a single click coming from the engine. I towed it home, replaced the starter, the solenoid, and the battery cables (plus the battery is new and charged). When I tried connecting the neg cable, the car tried to turn over, but a neighbor told me that sometimes the magnets inside the solenoid can get stuck together and cause that. I tapped the top of the solenoid a few times, then the car started right up. I drove it a few times the next couple days, but today when I tried to start it, it had the same problem as at the gas station- just clicked once when I turned the key. I replaced the solenoid again and the switch to starter cable, but got the same result as before. Has anyone excperienced this before and have any suggestions?
Old Feb 11, 2011 | 06:27 AM
MustangFTW
Guest
Posts: n/a
some thing similar happened to me, for me it was the positive haveing a loose fitting at the end where the wire connects to battery it kept breaking the circuit randomly. i replaced the fitting and it started working.
Old Feb 11, 2011 | 11:19 AM
Stangatic's Avatar
Stangatic
I am having the same exact problem now too. I was thinking that it was the ignition switch, but when i turn the key, I hear the click coming from the solenoid. I am going to have the car on the lift this weekend and will let you know what I find out.
Old Feb 11, 2011 | 06:49 PM
cougar70's Avatar
cougar70
Thanks guys, I really appreciate the help!
Old Feb 11, 2011 | 11:31 PM
JMD's Avatar
JMD
My old Lincoln had a similar issue, it would often only click when I hit the starter button, sometimes I would need to hit the button 20 times or more before the solenoid would kick the starter.
I ended up wiring a relay real close to the starter, the starter switch will kick the relay, and the relay will kick the solenoid with a very short run of wires from the battery cable, now it starts the first time every time.
It seems a little cumbersome, but it is not noticeable, and this was easier than trying to figure out why I was getting a weak signal from the starter switch.
Maybe not ideal, but it did solve my issue, and it is a driver....
Old Feb 21, 2011 | 05:15 PM
Stangatic's Avatar
Stangatic
mine ended up being a loose starter wire that would loosen itself when I drove the car. Solved the issue with a lock washer.
djbigskrilla
Sep 20, 2022 01:04 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
