Installing my Flamer thrower ignition coil??
Old Mar 29, 2011 | 05:07 PM
wonso79's Avatar
wonso79
Question Installing my Flamer thrower ignition coil??
O.k. I have the old coil out and the new one in. However the instructions are telling me if my car has a ballast resistor or resistance wire i need to remove it from the coil since I am using a 3.0 OHM coil for my inline 6. Is this the wire that comes from the engine guage feed wiring harness?
I am also hooking up my Pertronix Igntion from the distributor to the coil. This is why I am confused.
Old Mar 29, 2011 | 07:05 PM
wonso79's Avatar
wonso79
I need to know if I need to hook up a different wire that will supply 12volts to the coil rather than the resistor wire that I have read only supplies 9volts.
Old Mar 29, 2011 | 07:21 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
You have a pink resistor wire from the ignition switch to the wiring harness connector at the firewall that reduces the voltage to the coil. This is the stock setup to keep the points from burning up. At least that's how it is for the 8s, I imagine it's the same for the 6s.
You can use splice connectors to run a solid wire in parallel with the pink wire, just attach the new wire as close to the switch as you can at one end, and as close to the connector as you can at the other end. The idea is to eliminate as much of the pink wire as possible.
Or cut the pink wire and run just a solid wire in its place.
Either way will bring the voltage up to 12 which is what the coil is designed to use.
Old Mar 29, 2011 | 07:28 PM
wonso79's Avatar
wonso79
What happens if I just leave it stock and connect it? Will the car run fine?
Old Mar 29, 2011 | 08:07 PM
emttrevor's Avatar
emttrevor
Ive tryed that on a v8 setup and it didnt end well for me. You need to run a new wire, the plektronics will be what lets you down if you dont. I just ran a new wire that was 12volts once the key was turned on and left the other in place. I melted my wiring going to the voltage regulator before I learnt that one.
Old Mar 29, 2011 | 08:27 PM
Oxnard Montalvo
It might... Then again it might not.
There's only one way to find out.
Old Mar 29, 2011 | 11:02 PM
nba1341's Avatar
nba1341
I run the stock pink wire with my flame thrower (pertronix?) ignition coil. Never had any problems and I run the pertronix ignitor (that replaces the points) in my stock distributor
Old Mar 30, 2011 | 12:38 AM
tx65coupe's Avatar
tx65coupe
My car was originally an I6 and it has the pink resistor wire too.
Old Mar 30, 2011 | 05:03 AM
wonso79's Avatar
wonso79
Thanks for all your help!! I think I will run it with the pink resistor wire and see what happens. Wish me luck!! I will finish hooking it up tonight and let you guys know what happens.
Old Mar 30, 2011 | 05:37 AM
kalli's Avatar
kalli
as said it works for some, not for others.
bypassign the wire is actually very simple just like oxnard says. you don't need to cut anything
get the dash cluster out and from the ignition switch there is a green/black wire about 2 inch long and this then changes color (after a connector) to pink color.
Simply get split connectors (you know the ones that cut into the original and the new cable) and attach one at the front of the pink wire with a new cable running parallel and do the same thing at the back of the pink wire.
if you ever want to remove it just open the connectors. Job done.
the pink wire is actually resisting current, so you basically attach a non-resisting wire (normal cable) parallel to it so the power goes through that. voila! full 12V at coil
