Cold Start
Old Apr 8, 2011 | 05:12 PM
wonso79's Avatar
wonso79
Default Cold Start
Why is it that if you don't let an inline 6 warm up it runs like crap?
Old Apr 8, 2011 | 06:11 PM
MustangFTW
Guest
Posts: n/a
choke isnt open.
Old Apr 8, 2011 | 07:05 PM
wonso79's Avatar
wonso79
That would make sense, I'll have to check that out!! Thanks!!
Old Apr 8, 2011 | 07:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
my inline 6 in the truck runs perfectly fine cold...
Old Apr 8, 2011 | 07:35 PM
wonso79's Avatar
wonso79
I think I'll have to check out the choke and see if it's actually working. I know my choke tube is all rusted and who knows maybe there's a crack in there.
Old Apr 8, 2011 | 07:39 PM
MustangFTW
Guest
Posts: n/a
most carbureted cars need to warm up for a minute before running smoothly. Is your fast idle working? let the fast idle run for a minute then go, also make sure your idle is set correctly, nothing is more annoying then a cold engine with low idle.
Old Apr 8, 2011 | 07:47 PM
wonso79's Avatar
wonso79
It starts up after a few tries when its cold and idles great, once I give her gas it starts chugging. After the car warms up for about 3 or 4 minutes then it runs without any chugging. I really think it must be the choke.
Old Apr 8, 2011 | 07:57 PM
MustangFTW
Guest
Posts: n/a
the chugging is from the choke being closed, not enough air gets in to match the amount of gas you pushed so it "chugs". i have the same issue takes a couple tries to turn on then idles great, open up the hood and take off the filter and observe the choke, it should open slowly over the course of approx 5-10 mins idling, less if your driving. also check your air/fuel screws, for my autolite 2100 their on the front of the carb, on an inline 6 you probably have a autolite 1100, there screws with a spring on them, look up how many turns they should be turned out, for mine its 2.5 turns out from tightened.
choke can be a pain to set correctly, either have a load of patience and a detailed guide or take it to be tuned professionally.
Old Apr 8, 2011 | 08:12 PM
Canary94GT's Avatar
Canary94GT
Yeah mine takes 2-3 times to start when it's cold.
It shudders for a few minutes if I let it idle, but usually the shuddering goes away if I were to give it some gas.
Old Apr 8, 2011 | 08:59 PM
frdnut's Avatar
frdnut
That may be your problem right there..Not enough heat to turn the choke off quickly enough as the engine gets warm..
