starter spacer
Old Aug 28, 2005 | 10:17 PM
caballo66's Avatar
caballo66
Default starter spacer
i'm looking for a spacer for my starter for a 289, c4 transmission stang. do they exist? i put a new flywheel on and the counter weight is hitting the starter rim and just below the starter gear resulting in a knocking noise when turning the engine and metal shaving at the bottom of the bellhousing. also, the counter weight actually snapped off halfway and i have to get it welded back on.[:@] so, rather than replacing the new flywheel, i figured i'd just space out the starter. thanks.
Old Aug 29, 2005 | 01:02 AM
Riven02's Avatar
Riven02
Default RE: starter spacer
Oreilly's will carry a shim kit. I would make sure that you have BOTH drain pulgs lined up with holes in the flywheel. There are 3 holes in the flywheel because the weight is weilded over the 4th one usually. So if u lined up only one drain plug the other could be pushing the weight outward causing it to hit.
Old Aug 29, 2005 | 02:19 AM
caballo66's Avatar
caballo66
ill have to check that out...thanks for the info.
Old Aug 29, 2005 | 02:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
Your starter fits into the hole very snugly, so I would suspect the flywheel is not properly fitted, and not the other way around. Putting shims on starters is asking for trouble.
logan409
Sep 26, 2015 07:43 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Webster454
Sep 7, 2015 04:59 AM
