port efi 1970 fastback
Old Apr 29, 2011 | 11:31 AM
THEracingLEGEND's Avatar
THEracingLEGEND
Default port efi 1970 fastback
my coworkers at work are all telling me to install a port fuel injection system on my 1970 fastback 351w instead of something simple like a holley efi carb, any suggestions on how this would work or the steps to install a port side injector system???
Old Apr 29, 2011 | 12:02 PM
rtintwo's Avatar
rtintwo
This is a relativly simple conversion because ford already did the hard part. The windsor series was converted over to EFI in the 80s. Some time on craigslist and you will be able to find an intake, harness, fuel rails etc for a few hundred bucks. just make sure you buy a computer from a mustang, cause of the firing order.
You will be alot more reliable and have more performance parts available to you with the ford setup.
Old Apr 30, 2011 | 02:26 AM
andrewmp6's Avatar
andrewmp6
Yeah you want easy look in to the ford factory efi most f trucks and borncos used the 351w efi.Or i believe you can use the 5.0 efi with a different lower intake for it i may be wrong tho
Dokilar
15
Oct 16, 2015 08:13 PM
b8checker
Oct 8, 2015 12:55 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
b8checker
Sep 30, 2015 07:11 AM
