306 build up
Old May 6, 2011 | 07:40 AM
timmyisevil's Avatar
timmyisevil
Default 306 build up
Now i hate asking people to guess my hp but i can't take it anymore so i want to hear some numbers if i could thanks in advanced
-302 block over .30(306)
-Flat top 4 vavle relief pistons
-windage tray
-7qt front sump oil pan
-stock crank and rods with arp hardware
-Hydraulic Flat Tappet,292/292, Lift .512/.512........maybe
-650 Holly or a 600 Double pumper(need to pick one)
-Longtube headers,H pipe,2 1/2 to the axle
-stock c4
-8 inch 3.00 rearend
HEADS
-289 that will be fully PP
-oversize valves
-Roller rockers
-Eddie performer intake matched to heads when they are done.
motor is not in the car yet so some of this can and will change most is done. Again thanks
Old May 6, 2011 | 08:33 AM
Starfury's Avatar
Starfury
Someone will inevitably plug this into desktop dyno, and I'll leave that part to them, but I've got some build comments for you.
Why are you spending that much money on working over the factory heads? For a bit more money, you could probably get a set of aftermarket heads that flow better out of the box.
The 3.00:1 gears and stock torque converter are going to bog the motor down with a cam like the one you're talking about. You'll get more performance gain from switching to 3.55's or the like and picking up a torque converter matched to the cam than you will out of rebuilding the motor.
Stay away from the double pumper. You'll need a stick and/or low gears to pull that off.
Old May 6, 2011 | 09:18 AM
timmyisevil
I got the heads from my uncle for cheap, so i figured id give them a try. And i know i will need to change my converter just not sure which stall to go with, and i will be putting in 3.73 in the rearend.
Old May 6, 2011 | 11:29 AM
kalli's Avatar
kalli
haven't shoved it in the desktop dyno, but i don't think it matters if its 280 or 320. it probably will be around 300 at flywheel I'd guess. depending on how it's build. missing info like Compression ratio, valve sizes, exact cam, specs and how high (rpm) you'd dare spinning this
Old May 6, 2011 | 03:23 PM
Iskwezm's Avatar
Iskwezm
sounds like a VERY mild build, the cam is too big for everything else.
Old May 6, 2011 | 04:27 PM
timmyisevil
would it be better to grap a set of 351w heads or some E7s?
i would like to run a solid lift cam what would i have to change for that?
Old May 6, 2011 | 07:31 PM
Iskwezm's Avatar
Iskwezm
351 heads will flow more, but with a bigger chamber you lose compression, which affect power and then the cam size will also play a part again.
Old May 6, 2011 | 09:03 PM
Starfury's Avatar
Starfury
But if he's rebuilding, he can pick the pistons he needs to match the bigger chambers.
svfetter
Oct 5, 2015 11:39 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
